Buhl Innsbruck Electric Wall Screens are the perfect choice for applications which require an electric screen but where a recessed installation is not desired or feasible. All Buhl Innsbruck Electric Screens feature the convenience of an RF remote control for screen operation. The versitile bracket system can be used for either wall or ceiling mounting.
Product Features:
• Ideal for applications where a recessed installation is not desired or feasible
• Universal spring-loaded brackets attached to rear of screen case can be used for eiither wall or ceiling mounting
• Newly designed tubular motor is CE and UL Listed
• Screen surface can be cleaned with mild soap and water and is flame retardant and mildew resistant
• RF remote control included
• White aluminum housing blends into any decor
• One year warranty
Screen Fabric Information:
• Matte White
• The most versatile screen surface and the premier choice when ambient light is controllable. It evenly distributes light over a wide viewing area while colors remain bright and life-like with no shifts in hue. Screen surface can be cleaned with mild soap and water. Flame retardant and mildew resistant.
