COPERNICUS EDUCATIONAL PRODUCTS TEC1010 TECH TUB TROLLEY WITH 1 PREMIUM - HOLDS UP TO 10 TABLETS
This unique mobile trolley holds 1 Tech Tub and is an ideal solution for transporting small quantities of devices from one location to another. The Tech Tub includes a ten outlet USB hub that allows you to charge tablets and sync Apple devices in One unit.
Features- Includes 1 Premium Tech Tub with adjustable dividers and cable management pocket
- Holds between 6 and 10 iPads or other tablets depending on the size of your device and case check compatibility chart
- New adjustable dividers to accommodate up to 10 devices and small cases
- New Cable management pocket to keep cables organized out of sight and in-line with each device
- 10 outlet USB hub that can be mounted internally or externally to support up to 10 devices in one tub
- Please note that when USB hub is mounted to the outside of the Tech Tub it will not fit in Tech Tub Trolleys and Carts
- Charge tablets via USB and sync Apple devices with Macbook using an Apple Configurator Software
- 2 padlocks with the same keys
- Cable management for power strip cord
Specifications- Dimension: 27 H x 14 W x 19 L
Price: 636.86
