MONOLITH 7 X 200 WATTS PER CHANNEL MULTI-CHANNEL HOME THEATER POWER AMPLIFIER
The Monolith 7 is a state-of-the-art; high-performance; audiophile-grade multichannel home theater amplifier. Rated at a full 200 watts per channel into 8 ohms and 300 watts per channel into 4 ohms; the Monolith 7 is capable of driving the most demanding home theater systems and reproducing the most dynamic soundtracks; while also articulating all the subtle sonic details found in music. Supercharge your existing receiver or create the foundation of a no compromise home theater system with the Monolith 7. Designed; engineered; tested and assembled in the USA.
Power:- A true 200-watt experience. Unlike most amplifiers or receivers; the Monolith's 200 watts per channel rating is measured with all seven channels driven across the full power bandwidth of 20Hz to 20kHz into 8-ohm loads. Additionally; there is NO current limiting and there is no protection circuitry in the amplifier circuit path. Even if the speakers' impedance drops to a low level; the Monolith is robust enough that the current is never limited
Dynamics: - High resolution audio delivers the best in music and movie soundtracks. You deserve an amplifier capable of delivering clear and clean audio across a wide dynamic range! With a more than 120dB signal to noise ratio; the Monolith 7 can clearly and accurately articulate the quietest portions; the loudest portions; and everything in between
Class AB:- More efficient than Class A; many high end; audiophile grade amplifiers utilize a Class AB design
Specifications- Dimension: 12 H x 24 W x 24 L
Price: 2513.82
